Mike CA said: (quoted from post at 22:26:00 10/22/07) Can someone tell me what those funky rear rims are about? I've seen them a couple times, but don't know what they are called or understand what they are for.
Mike,
Those are power slip rims. They allow you to adjust tire spacing without moving the hub on the axle.
Basically you loosen the lugs on one side and the pair of locks on one of the steel bars on the rim, apply brake to the opposite tire, put it in 1st or reverse (depends on if you want to go in or out) let out clutch and it'll move the tire in or out on the rim. Tighten everything back up and repeat for other side.
All I know is that they are friggin heavy.... even if the tires aren't loaded...
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
