Afternoon Smigelski, Turn your steering wheel shaft back and forth to see how much play you have before you get any motion to the bottom of the steering box. You may be able to take off the large acorn nut on the fron of the steering box and put a large shim washer between that nut and the outer race of the bearing. Also make sure the steering arm that is on the underside of the steering box is tight, if its loose and the woodruff key on that shaft is worn your going to have problems there also !
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
