Farmall 300 sheetmetal hardware
Posted by KSfarmmer on October 23, 2007 at 14:15:31 from (24.255.244.98):
Where do you guys buy the hardware for holding on sheetmetal? Not sure what they are called, but it is a nut with a clip that holds the fastener inside a square hole? Archives indicate they might be called cage nuts? Are these available from NAPA or do you have to go to a dealer or a fastener supplier? Looking for the least expensive fix, not so worried about originality.
Thanks
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
