Good question, complex answer. The diagrams (Bob M's) will be fine for making stock lights with equivalent wattage 12v bulbs work correctly. If trailer lights are needed, or additional tractor lights, they should be supplied separately from the load side of the Amp gauge with a separate 20 amp fuse and switch. The original light switch will not carry the load. Lights should be placed on the wagon such that all corners are lit. at the height of the flat of the deck. Reflective tape should be placed on the rear to mark the top right and left corners of the rear endgate. Running 14 gauge Zip cord (two conductor vinyl covered appliance wire) down each side works well and is tidy. If you use LED lights, the cord can be 18 gauge, and the light switch would handle that added load. It will not handle bright halogen headlights or tail illumination lights. I would use a switch box and fuse that can be disconnected easily and kept with the trailer lights to make it easy to get ready the next time. Good fun, JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
