Posted by Andy in Beloit on October 24, 2007 at 05:52:49 from (71.90.131.138):
In Reply to: 450 won't start posted by David Robinson on October 24, 2007 at 05:30:42:
David - I had the same problem with my truck this summer. Check the dist. cap and rotor. Also check the coil, coil wire, and the wiring to the coil. Sounds like a lack of fire problem for sure. Also check the cap to see if its come loose or has moisture in it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
