Re: SMTA Reservoir
Posted by Wardner on October 24, 2007 at 12:52:18 from (4.154.247.224):
In Reply to: SMTA Reservoir posted by Andy in Beloit on October 23, 2007 at 23:19:56:
I believe those are delayed lift ports for use with cultivators. They would be activated with the pull handle to the right of the steering wheel.
I have three ports on my SMTAs. I presume the single port activates right away. The paired ports go to the rear implement and take a second or two to activate. This would be similar to the earlier style Liftall.
An operator's manual would have the info.
