Re: cluch
Posted by Janicholson on October 24, 2007 at 17:16:07 from (66.173.50.126):
In Reply to: cluch posted by Jim De Moss on October 24, 2007 at 16:49:40:
The issue is not the master clutch, it is the TA clutch adjustment. The manual will detail the procedure. The TA will burn out if left that way, do it now, by the book, and all is well. By the way, the TA is not a converter, it is a set of planetary gears with a clutch, and a overrunning clutch that operate them. No fluid coupling, JimN
