Re: 560 nf shimmy
Posted by RR Mech on October 24, 2007 at 20:53:39 from (12.154.7.21):
In Reply to: Re: 560 nf shimmy posted by Joe Evans on October 24, 2007 at 06:05:19:
Read the book carefully. There is an adjustment to set the rack closer to the pinion.It entails turning the sleeve some in the housing. The sleeve is built eccentric and can be turned a few degrees to tighten or loosen the clearance. Hope this helps.
