SMTA hydraulic pump pressure
Posted by SDE on October 25, 2007 at 14:38:29 from (69.179.10.241):
Ed put a loader on his SMTA that had been on a JD A. The loader will not lift heavy loads like it did when on the JD. He checked the pressure with a gauge that hooked up to the QD. He remembers that the pressure was between 1200 and 1400 lbs. He was wondering if this is the correct pressure for a Thompson pump #362 175 R94?
Or does he need different rams? They don't leak down. Are some rams not compatiable with some pumps?
Thank you
SDE
