Posted by K.B.-826 on October 25, 2007 at 18:39:47 from (24.197.177.61):
In Reply to: IH 464 Running Hot posted by jjohnson on October 24, 2007 at 19:59:23:
Was it running hot before the water pump and radiator were replaced, or did the problem show up right after replacing them? If this happened right after replacing those parts, I'd suspect that the water pump impeller is spinning on the shaft, impeller pressed on backwards or not far enough, or a problem with the radiator recore job.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
