Re: 685, 684, 674 hydraulic plumbing
Posted by Fromjb2 on October 25, 2007 at 18:53:21 from (99.241.179.24):
In Reply to: Re: 685, 684, 674 hydraulic plumbing posted by karl f on October 24, 2007 at 20:50:39:
Hi Karl, yes inlet to remote valve would be from the from the banjo fitting and outlet could either go to tank filler hole or the fitting on #37. I am assuming it is a simple remote valve or has it an inlet, outlet and a dump outlet(used on front end loaders to control the drop speed)?
If it has the dump outlet, then dump outlet to tank filler and out to fitting on #37.
Hope this helps
JimB
