No till grain drills
Posted by DannyTN on October 25, 2007 at 19:06:37 from (66.21.211.175):
Been thinking of buying a used no till drill for pasture seeding. Have no familiarity with them. What are good things to look for in a drill or would be a good machine to look for?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
