Re: Update on Loose 240 U Steering Problem
Posted by J.J. from Afton on October 25, 2007 at 21:36:59 from (71.215.235.21):
In Reply to: Update on Loose 240 U Steering Problem posted by PaulW_NJ on October 25, 2007 at 17:03:43:
You could always look at welding the taper up and turning it down to where it would fit tight again. Its always worth a try depending on parts cost.
