If you you have battery ignition with a distributor you need constant voltage fed to the coil. Have the battery checked to see if it has a weak cell and check your charging system to make sure its working so it will keep the battery charged. If you have a magneto it doesn't require battery voltage as it creates its own voltage when the magnets pass by the coil. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
