As Will said an intake can cause that. Look close at the intake runner going to number 3-4 cyl for leaks or loseness. Also check it for a small rust hole near where the exhaust wraps around the runner and even inside where the exasut pipe lets out. Carb cleaner or a propane torch with the torch head removed will work also to find leaks. To check the inside part in the exhaust for leaks use brake cleaner and with the manifold removed, spray the inside intake runners completly and see if any wetness appears in the exhaust side. It may just be a small area so you might have to get a small mirror to look down inside. They can get rusty in there from use or from sitting with a plugged up rain drain hole and crud sitting in the bottom of the exhaust part above the carb. Another thing to do and I would do it first, would be pull all the plugs and look at them good. It may just be those 2 plugs flooded and are shorting and that could save a bunch of searching for the leak in the manifold.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
