Re: Okay, I'm stymied
Posted by Janicholson on October 27, 2007 at 16:37:13 from (66.173.50.38):
In Reply to: Okay, I'm stymied posted by ScottyHOMEy on October 27, 2007 at 13:44:22:
Two items. The throttle lever is almost always the way yours is with a blank spot at the bottom end.
The second is linkage wear. If there is any appreciable (more than .003") they need to be reamed out and new bushings put in to make it nice, or drilled and a tiny bit larger rod used to tighten it up. If it is not getting to both ends, that is where I would look first. JimN
