Re: Farmall 300 live hydraulic
Posted by James Babcock on October 28, 2007 at 05:29:12 from (72.161.76.68):
In Reply to: Farmall 300 live hydraulic posted by Dick fm Iowa on October 28, 2007 at 03:34:29:
Similar thing happened on my 300 about 10yr ago (back when my memory was really good). I think there was a rubber seal with a metal collar that goes on the pump driveshaft and keeps the hyd fluid on the pump side. If that seal fails, then hyd fluid can get into the crankcase via the timing gear area. Case IH dealer ordered the seal, and the shaft was still good. Install was fairly easy since you can put the seal on from the outside of the pump after removing pump from the engine. If the shaft is too worn for the seal to work, then some of the other guys can hopefully explain how to put a bushing or similar fix on the shaft. HTH good luck
