Re: H won't start
Posted by John T on October 28, 2007 at 07:16:49 from (66.244.83.147):
In Reply to: H won't start posted by Farmall Ed on October 28, 2007 at 06:09:11:
Didnt we talk about this on another board???????
Anywho, are you saying you have a mag thats been converted to battery power for the coil????? If thats so the very first thing you gotta have is good hot battery voltage getting to the coils high input (NOT to points) terminal when an ignition switch is turned on and a dead or very weak battery cant supply that and isnt getting there in a direct to starter jump.......
Before I can help you I gotta know if this is a conversion (battery powers the coil) or not??????????? If its still a Mag Im out to lunch on IHC mags but can help if its a battery powered mag conversion.
If its a conversion shes not gonna run till you get good hot batetry voltage to the coils high input (NOT to points). If it has an IGN switch maybe its bad or try to hot wire it n se if she fires then. If its a conversion get a test lamp n place it on the coils input n see if it lights up when an IGN switch is turned on??? If not so sparky
If its still a Mag ask the IHC mag gents to help ya
John T
