Re: Farmall 300 live hydraulic
Posted by Janicholson on October 28, 2007 at 08:49:33 from (66.173.50.34):
In Reply to: Farmall 300 live hydraulic posted by Dick fm Iowa on October 28, 2007 at 03:34:29:
Put the engine at TDC for this action. (as outlined below in the other posts) The timing needs to go back where it belongs. Note the position of the rotor as you withdraw the pump, and make sure it ends up at the same place. It should be an easy fix. JimN
