Farmall 350 Bleeding Hydraulic system?
Posted by Pat Baker on October 28, 2007 at 13:22:50 from (67.55.253.50):
I have an old Farmall 350 tractor with a front bucket on it. I had to replace one of the hyd hoses and at the same time I drained the trans fluid and replaced as it was very milky. I started the tractor and you can see the hyd cylinders trying to work (they move about an inch or so) and then nothing. I pulled off one of the quick connect copplers and had a very hard time putting it back in due to the hyd pressure on the ball. I did get it back on and the cylinders still wont go up. Is there a way to bleed the system to make sure that all the air is out of the lines? I am thinking this may be the problem.
