Re: Farmall-A Hand crank
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Curt Cooke on February 20, 2000 at 19:41:52 from (207.75.224.71):
In Reply to: Farmall-A Hand crank posted by Courtland on February 20, 2000 at 18:38:02:
Courtland, no springs. You've got what there is. The pulley is designed to push the crank out to you when the engine fires. If the engine fires prematurely you're on your own but if everything is timed right you should have no problem. Don't like the bolt though, it should be a pin.
Curt
Post A Followup
: Re: Re: Farmall-A Hand crank
