Posted by Wayne in MN on October 29, 2007 at 06:08:28 from (71.13.40.149):
In Reply to: H tractor surging posted by Dan Gingrey on October 28, 2007 at 21:22:02:
With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw (on the bottom facing down to the rear) in until the engine begins to starve for fuel. Then turn the screw out until the engine begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out 1/2 turn or more beyond the "sweet spot" to be sure the engine isn't starving for fuel and can develop its rated power.
The same procedure can be followed for idle mixture with the addition of the idle stop screw (just to the rear of the governor shaft tube) to set the low speed RPM. On the "H"& “M” carb, the idle mixture screw (faces to the front just below the idle stop screw) is an air adjusting screw so turning in will richen the mixture and out will lean the mixture. Repeat the procedure again to make sure “all is well”.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
