Well like others have said and if the filter is clean and the screen is clean then i would have to say that ya may have a leaking sump check plug or ya may have some sticking valves in the MCV . ANd may need a new spring kit and a real close look at the valves . Not sayen that you could not do the job but ya will need atleast one special hyd fitting a test gauges that will read 600 lbs To set the pressure reg. spring as it may need to be ground of to reduce pressure or may need to shimmed up. I had one 966 that was doing the same thing and foundthat the pressure reg valve was scored and stuck.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
