Re: 1066 no steering, brakes when cold
Posted by Owen Aaland on October 29, 2007 at 08:58:37 from (65.174.247.81):
In Reply to: 1066 no steering, brakes when cold posted by rplanty on October 28, 2007 at 19:42:49:
Do things work OK after it starts to work? Do the rear hydraulics work OK right from the start or do they begin to work only when you get streering and brakes?
If the problem is just that it takes a long time to get the pumps primed, if it is not low on fluid, the most likely cause is an internal leak on the oil pickup tube between the clutch housing and rear frame. The way to test for the leak is to overfill the rear housing by about five or six gallons and see if theat cures the problem. If things work OK when overfilled, you can use it that way, or do a rear split to replace the o-ring between the frames.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
