Posted by G Spence on October 29, 2007 at 12:33:59 from (65.54.155.58):
In Reply to: Re: Low oil pressure posted by the tractor vet on October 29, 2007 at 11:02:22:
I used a set of test gauges, not the dash gauges. I assumed the test gauges were working fine, could that have been a mistake?It has new pistons, sleeves, rings and valve job. I used rotella 15-40 wt. The presuure started at 30 lbs. and in about 20 minutes dropped to 10 or less. I pulled the pump and it was clean and the valve and spring working and it was only slightly out of tolerance about 0.009. The crankshaft bearings were worn to the copper. the crank had been turned already the bearings were .030
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
