Re: Farmall M wide front end ??
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Brian Schmidt on February 20, 2000 at 21:27:49 from (216.178.176.197):
In Reply to: Farmall M wide front end ?? posted by medfarm on February 20, 2000 at 21:06:57:
I just saw a 53 Super M in about the same condition you stated. It also had a wide front end. I think the front end also stuck out in front. It was an aftermarket attachment. The block at some time had froze and cracked the outside. They had a metal plate bolted and gasketed over the crack. Looked like a typical farm fix. All that was missing was the balen wire.
It ended up going for an unbelievable $3750.
Post A Followup
: Re: Re: Farmall M wide front end ??
