Re: 450 CLUTCH ?
Posted by Janicholson on October 30, 2007 at 05:49:49 from (199.17.6.122):
In Reply to: 450 CLUTCH ? posted by Hoss357 on October 30, 2007 at 04:25:48:
The easiest way is to mount it on the shaft and turn the shaft with a wire or other indicator up next to the friction surfaces as they come around. This is called axial runout. If the runout is serious (in the 1/8" category) replacement is best. the warped hub will rewarp in use and cause issues later. If minor rebending the hub (not arms) to get it straight is OK, but a call you must make. While there be sure to dress the splines on the input shaft to be sure the friction disk hub slides well on it. Triflow spray leaves a teflon dry film and can be used on the splines. JimN
