Re: Bad three bolt steering spindles
Posted by RustyFarmall on October 30, 2007 at 13:13:57 from (66.43.253.19):
In Reply to: Bad three bolt steering spindles posted by Bob Haiar on October 30, 2007 at 09:40:20:
A good welding shop can repair those wobbled out holes in the hub, and then the trick is to make sure that the bolts are TIGHT.
