Posted by SDE on October 30, 2007 at 16:31:46 from (207.118.218.174):
In Reply to: 450 CLUTCH ? posted by Hoss357 on October 30, 2007 at 04:25:48:
My pressure plate had about .03 wear from a button clutch. I would assume that the flywheel had that much also. I had the flywheel ground for about $25 and trued the P.Plate myself because they could not do it. A normal clutch disc will be a little larger outside diameter and the inside diameter will be smaller. You could replace a normal clutch disc with a button clutch, but not a button with a standard disc, unless you have flywheel and P.P.trued up. I had two tractors apart this summer an had one of each style clutch to compare to each other. If I am wrong, I hope someone will say so. SDE
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
