Re: Update on Loose 240 U Steering Problem
Posted by DAVE240 on October 31, 2007 at 05:51:58 from (24.213.190.134):
In Reply to: Update on Loose 240 U Steering Problem posted by PaulW_NJ on October 25, 2007 at 17:03:43:
I HAVE A QUESTION ON HOW TO REMOVE THE STEERING SHAFT U JOINT FROM THE WORM SHAFT. I HAVE DRIVEN OUT THE STEEL PIN THAT GOES THRU THE U JOINT AND SHAFT. BUT CAN NOT FREE THE JOINT FROM THE SHAFT.
ANY HINTS??
THANKS
DAVE
