Re: Pouring a Shop floor...for heavy machine work.
Posted by BOBM25 on October 31, 2007 at 08:45:08 from (69.68.42.16):
In Reply to: Re: Pouring a Shop floor...for heavy machine work. posted by Janicholson on October 31, 2007 at 08:16:05:
That sounds good. If the concrete is indoors, a good footer under the doorway is a must, I think. 12-18 inches think, min of 32in deep, below the bottom of the floor, the entire width of the door way. Anchor the floor to this. That will keep heavy equipment from busting up the edge and keep the frost from raising the floor so your door closes properly in the winter. I would also seriously consider some kind of radiant heat in the floor. I think this keeps the concrete dried out and warm, thus eliminating sweating and helps resist cracking. To finish, I would use one of those fairly new epoxy paint systems rather than Thompsons or some clear sealer like that. Once you put that stuff down, not much else will lay over top without flaking off.
