Re: Pouring a Shop floor...for heavy machine work.
Posted by benny2 on October 31, 2007 at 09:33:23 from (66.45.222.44):
In Reply to: Pouring a Shop floor...for heavy machine work. posted by WonderingAl on October 31, 2007 at 07:58:11:
Janicholson
Got it right on! Should I add the floor should have separators expansion joints around the floor contacting the foundation. This separation allows for a full floating floor. Consider drains and a grease trap too. The river rock should be of the round not crushed type. Depending on your soil conditions there should be at least 2" up to 4" ballast rock then a layer a 4" of 3/4" minus with fines well compacted over the ballast rock just under the "round river rock" with the appropriate number of separators and crack preventer lines in the finish this should provide for a perfect "floating" machine shop floor.
Most local contractor will either quote for the cheapest or minimum legal approved and not for the heavy floors needed in a machine shop. So dont let them tell you it is not needed! This floor make up will fly in most parts of the USA not including perma-frost applications.
PS You may consider exposed steel beams in the floor if crawler trac type tractors are going in.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
