Re: E4A magneto and F4
Posted by russ hamm on October 31, 2007 at 11:20:26 from (63.245.179.200):
In Reply to: E4A magneto and F4 posted by Duanes on October 31, 2007 at 09:33:14:
The conversion part i can answer. The coupling part at the governor is different, unless you can find a coupler that will go from small to large, they are around. Basically, the f-20 f-4 equipped setup will fix you up. Before i found that out, we made a coupler out of aluminum once. I'd hafta lookup the point gap.
