Posted by El Toro on October 31, 2007 at 17:37:45 from (64.12.116.73):
In Reply to: Farmall posted by Greg318 on October 31, 2007 at 14:57:45:
Those engines are very easy to work on and you can do that engine job yourself. Take a lot of pictures and make a lot of sketches and notes when tearing the engine down. They will help when you do the engine assembly. Get yourself a good shop manual too. Have the block degreased, the cylinder head magnafluxed and have new springs, valves, and guides installed if it needs it. You need to have the crankshaft checked for wear by your auto machine shop too. They can supply the new bearings. It may only need to be polished unless it is worn beyond specs and needs to be ground undersize. They can get them too.
Your sleeve and piston kit can be purchased here on this forum, but they will need the serial number of the tractor to get the correct kit. You could have the C123 engine with 3-1/8" pistons, but you can use 3-1/4" sleeve kit if it does. Does it have a water pump? Hal
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
