Posted by John T on October 31, 2007 at 21:12:49 from (66.244.83.147):
In Reply to: diode question posted by keith smith on October 31, 2007 at 19:07:36:
Keith, Instead of a diode I use a 10 ohm current limiting protection resistor in that excitation circuit and when guys use idiot lights in the same location they are even more resistance then that. The resistor alone should prevent run on from alternator feed back but if not, only then would I add a diode. If the ignition is off there shouldnt be any voltage source getting to that diode if your excitation circuit is wired corectly and when on there will only be current flow until such time the alternator is self exciting so it shouldnt get hot IF THE ALTERNATOR IS OKAY AND SHES WIRED CORRECT UNLESS YOU LEAVE THE IGNITION ON????
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
