Re: Front Weights for an H ??
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by john d on February 21, 2000 at 08:10:56 from (206.141.74.34):
In Reply to: Front Weights for an H ?? posted by Jim on February 21, 2000 at 07:24:31:
Doesn't look especially pretty, but for occasional use you can hang a rear wheel weight on the channel iron along side the engine. Neighbor used to do that with an M to keep the front on the ground when plowing.
Another option would be to weld up a bracket that bolted to both channels and extended in front of the tractor far enough to add some "suitcase" front weights from a later model.
Post A Followup
: Re: Re: Front Weights for an H ??
