Re: H starting issue(s)
Posted by El Toro on November 01, 2007 at 04:05:18 from (64.12.116.73):
In Reply to: Re: H starting issue(s) posted by CJAA on October 31, 2007 at 18:39:52:
You should be able the turn the engine by hand. I would squirt some engine oil into each cylinder and see if you can turn the engine by hand. You may need to use the starter to get the cylinders coated with oil then see if you can turn it by hand. Does it show any oil pressure when using the starter to crank it? You can reinstall the plugs and see if it will crank with the plugs installed. If it won't, I think you will need to pull the head. Before you do that put another
help question on the Farmall forum. It may be less work to pull the pan and check your oil pan for metal particles. You could have some bearing
issues. If you do find metal particles I would
pull one bearing cap at at a time and inspect it.
Reinstall and retorque it if looks ok. Make sure you have good battery cables 00 if you're using 6 volt battery and soldered lugs. Was this engine recently rebuilt? They're hard to turn when everything is new, but you should still be able to turn it by hand. Hal
