Re: Farmall
Posted by Hugh MacKay on November 01, 2007 at 05:20:11 from (209.226.247.180):
In Reply to: Farmall posted by Greg318 on October 31, 2007 at 14:57:45:
Greg: Block part number is what you need when ordering a piston and sleeve kit. From what the other respondants revealed it's 54 Super A and if original engine, should have block part number 354898 R1 or R2, most likely R2. You will find an assortment of different kits will fit that block, all the way from 3" bore to 3-1/8" and 3-1/4". Which one is best, I'm not sure, I've always stuck with factory specs myself.
