Re: 300 utility Front Split
Posted by perrycountyfarmalls on November 02, 2007 at 03:47:55 from (71.72.111.89):
In Reply to: 300 utility Front Split posted by Dustin Bench on October 31, 2007 at 18:06:11:
one more thing...forgot to mention...I would not use it until it was fixed! You will need a lot more parts the longer you wait...I can't remember for sure, but I do believe you will have to pull the flywheel off. That is, if your internal bell housing bolts are the problem and not the external.
