Posted by old on November 02, 2007 at 08:45:32 from (4.245.1.145):
In Reply to: Re: Stuck '49 Farmall H posted by Harold From Idaho on November 02, 2007 at 06:54:26:
Use a rag eyc. to get out as much antifreeze from the cylinders as you can. Then use air pressure to blow out any thats left before you pout the ATF in the cylinders. Other wise the ATF will just float on the antifreeze and do you no good. If it doesn't pop free in a month of less you can try this is works some times but you have to be very careful doing this. In a safe place top off the ATF with a table spoon of gas and light it up. Doing that heats the sleeves/block and makes the rings/piston looser in the cylinder and some times thats enough to free it up. NEVER do that with the head on by the way
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
