Re: Handle on Farmall 450????
Posted by georgeky on November 02, 2007 at 09:37:11 from (64.12.116.73):
In Reply to: Handle on Farmall 450???? posted by David Robinson on November 02, 2007 at 08:21:53:
That handle is for the mechanical draft control on the fast hitch. It should have some notches on it. It is for plowing and other ground engaging equipment. They do work to some extent.
