Re: ...FARMALL 656 Diesel - 1966 - Power Steering...
Posted by bc on November 02, 2007 at 20:53:26 from (69.151.187.126):
In Reply to: ...FARMALL 656 Diesel - 1966 - Power Steering... posted by Shawn Alfonsi on October 30, 2007 at 21:40:00:
Shawn, Here is what I found out today which may not help you since yours isn't running.
I started it up, lifted the wheels off the ground, run the steering back & forth, closed the power steering lockout valve on the flow divider valve and shut off the tractor. I then turned the steering wheel and the wheels (still off the ground) manually turned with it back & forth a few times. That tells me the hand pump is working and it may be the flow divider valve. I will try to open it up from the front this weekend while on the tractor. I'll find out then if i can see somthing wrong or not. Tractor vet may be right on this on, I hope.
My international dealer (www.straubih.com) has internet access to the parts catalog like the caseih webiste has but this one allows you to check on the parts you want and forward it to Straub where they will email you back with the price of the parts, etc. I tried to price the pump element/rotor set for the hand pump and it came back as no parts available. All you can get are the seals, etc. They quoted me a new hand pump for $1078 so I'm glad that I don't have replace that.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
