Re: F-20 Rod bearings
Posted by El Toro on November 03, 2007 at 07:22:05 from (64.12.116.73):
In Reply to: Re: F-20 Rod bearings posted by Greg NE on July 22, 2007 at 08:03:17:
HI Greg, Do you have the torque spec for the F20 rods and the valve lash setting? Hal
