Posted by CNKS on November 03, 2007 at 18:41:08 from (216.144.104.128):
In Reply to: Re: 1940 H overheated posted by tackhammertime on November 03, 2007 at 16:42:15:
Capacity is 4 1/8 gallons. Drain it completly, including the block, put the correct amount in it and see what it does. Sometimes you "fill" the radiator, start and run it, then add to the proper level. Unless you ran it nearly dry, I doubt if you hurt anything. If it overheats again, drain and flush the system, also remove and clean under the plate on the left side of the engine. It will be full of crud. The radiator probably needs to be "rodded"--but it could be all that is holding it together is rust, meaning you may end up buying a new radiator. If so, the new one will likely be pressurized.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
