Re: cub 154 lowboy
Posted by John M on November 04, 2007 at 04:46:56 from (209.213.22.170):
In Reply to: cub 154 lowboy posted by danny masters on November 03, 2007 at 18:23:45:
I think maybe you just fried the starter. It should be negative ground. I dont have enough experience with the starter/generator setup, but I do have a 154. Its always worked fine. You could hook it up right and see what ahppens then. May be Ok.
