Farmall H trans oil
Posted by Gary Northrup on November 04, 2007 at 06:40:45 from (216.234.98.29):
I should replace the transmission lubricant in my Farmall H. Can I use the current Hy-Tran or a heavier gear lube?
Thanks, Gary
