Re: SA hydraulic pump seal question - where does leaking oil
Posted by georgeky on November 04, 2007 at 07:41:44 from (64.12.116.73):
In Reply to: SA hydraulic pump seal question - where does leaking oil go? posted by SteveNH on November 04, 2007 at 06:50:00:
If it is leaking the oil goes into the crankcase. If so your engine oil will be overfull. The whining can be caused by lift box being out of adjustment. It is critical that it be adjusted properly. If you can't do it, you should have someone who can look at soon. This is covered in the IT manual under stop clip adjustment.
