Re: SA hydraulic pump seal question - where does leaking oil
Posted by Hugh MacKay on November 04, 2007 at 09:30:04 from (216.208.58.175):
In Reply to: SA hydraulic pump seal question - where does leaking oil go? posted by SteveNH on November 04, 2007 at 06:50:00:
Steve: Don't jump to conclusions too quickly. You didn't say how exactly how much Hy tran you lost. Check to see if crankcase is level is rising first. Hydraulic oil levels will always be lower when rockshafts are in the forward position. That is why you check level with rockshafts in rear position, to prevent over filling.
The whine your hearing could well be levers out of adjustment.
