Re: 460 diesel trans main shaft
Posted by D Slater on November 04, 2007 at 15:08:56 from (71.164.57.221):
In Reply to: 460 diesel trans main shaft posted by polinidad on November 04, 2007 at 05:11:37:
If you have tractor split in front of transmission case, remove the bolts from main shaft rear bearing cage. Then push shaft and bearing cage to front(watch the shims behind bearing cage)when it clears at rear move shaft into a position to be lifted out the top. Don't know what your doing but shaft can be removed from rear also. Bull gear has to be moved out of way and differential removed. main shaft bearing retainer and the snap ring on shaft moved forward. Carefuly drive rear bearing forward until it will slide on shaft. Slide shaft to rear out of the gears and bearing. If there's a chance anythings not okay on transmission counter shaft I wouldn't recomend the last, because if there is a split at front will be needed anyway.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
