Re: starting in cold weather, and snow questions.
Posted by willie in mn on November 05, 2007 at 05:06:12 from (64.12.116.73):
In Reply to: starting in cold weather, and snow questions. posted by Idaho Ron on November 04, 2007 at 20:47:33:
Ron
Can't add anything about the starting issue,
BUT check the local/state rules.
Here in Mn it is illegal to push or blow snow ONTO or ACROSS a public road! This includes the ditch or other area between your property line & the actual driving surface.
A lot of people got into trouble by not cleaning up what they spilled & left on the road.
If an inattentative driver loses control by hitting a lump you left, or worse yet, hits you while plowing, you are automatically ONE HUNDRED PERCENT LIABLE for all damages, plus there is a criminal fine added.
Be careful
